burbleboy Posted June 5, 2012 Share Posted June 5, 2012 Re-named this post as i had a look at my standard fuel rail.When the pressure regulator i ordered arrives, the pipework looks straight forward...however, what do i do about the old set up? Surely if im redirecting pipes to new regulator the old regulator on the rail will leak fuel as it will not longer be needed. Do i just block off the old regulator inlet?Thanks in advanceAlastair Quote Link to comment Share on other sites More sharing options...
burbleboy Posted June 8, 2012 Author Share Posted June 8, 2012 Just my bloody luck. Went to fit regulator at work last night and bracket that bolts onto fuel rail is wrongly aligned. Hole doesnt match up to the rail hole. I just ordered adaptor plate there, can't fit the regulator as i bet the part wont be here on time. ragin now as i bet it wont arrive saturday...even with express delivery paid. Car booked for dyno this Monday hence the rush Quote Link to comment Share on other sites More sharing options...
noodels Posted June 8, 2012 Share Posted June 8, 2012 hope you get it sorted in time Quote Link to comment Share on other sites More sharing options...
