DIY mot/nct pre checks - Brakes
james
MOT Test of Brakes
Test Description
Brake efficiency and balace is usually checked on a roller brake tester. In certain cases where a roller brake tester may not be used (for example on certain 4-wheel drive vehicles) it may be necessary to check brake efficiency and balance on a road test, with a portable decelerometer.
Inside the car
Anti-lock braking system (if fitted) warning lamp is checked for:
function
sequence of operation
Footbrake
sufficient reserve travel on the footbrake
pedal rubber not worn to excess
correct operation of the servo assistance system
Parking brake
This could be hand, foot or electronically operated. Checked for reserve travel so that it doesn't reach the stops on application. The mountings will be checked for security and/or corrosion.
Under bonnet checks
master cylinder and servo unit are checked for leaks with the engine on and the brakes applied
servo unit will be checked to ensure it is operating correctly
visible metal or flexible brake pipes will be checked for corrosion, condition, fouling or leaks
Under vehicle checks
flexible brake pipes and any other metal brake pipes visible beneath the car are checked
discs and drums (external only) checked for condition and contamination
brake back plates and caliper securing devices are checked for condition and security
condition of the brake pads will be checked if visible
The assistant operates the handbrake and the condition of the linkages and/or cables is checked.
on some vehicles there will be a brake compensating valve beneath the car which will need to be inspected for fluid leaks
Brake performance check
The performance of the front and rear brakes and handbrake are checked for efficiency and balance using specialised equipment.
