vtec2011 Posted October 9, 2012 Share Posted October 9, 2012 Hi there.. Quite recently I start hearing this annoying noise when taping the accelerator pedal. Its also sounds like something is slack, making a sort of scraping noise. It only does it if the car is juddering (judders when its cold) or when pulling away from stand still. I think its either the inner drive shafts or the differential but not really sure. A couple months ago I have replaced the gearbox for a D16 gearbox, maybe its something to do with that? Any ideas or help will be great, thanks for reading Quote Link to comment Share on other sites More sharing options...
levi Posted October 10, 2012 Share Posted October 10, 2012 I have a squeaky noise when i accelerate too! Im almost sure mine is a belt, but they are all pretty tight and in seemingly good condition. Check your belts before you start playing with drivetrain i guess.. Mainly the alternator belt but your power steering etc could also be an issue. Get your head in the engine bay and have a listen to different parts and see if you can locate a noise with the car parked and engine idling. Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted October 10, 2012 Author Share Posted October 10, 2012 I have a squeaky noise when i accelerate too! Im almost sure mine is a belt, but they are all pretty tight and in seemingly good condition. Check your belts before you start playing with drivetrain i guess.. Mainly the alternator belt but your power steering etc could also be an issue. Get your head in the engine bay and have a listen to different parts and see if you can locate a noise with the car parked and engine idling.I do have a squeaky alternator belt which will not stop! I even fitted a new one on and it still speaks.. I have found out what the noise is which is the diff. I think its knackered because there is a lot of play in both of the driveshafts. So that's going to be the gearbox off for the 3rd time.. Quote Link to comment Share on other sites More sharing options...
levi Posted October 10, 2012 Share Posted October 10, 2012 Oh well doesn't sound like a simple job then :/ Quote Link to comment Share on other sites More sharing options...
civicturbo79 Posted October 20, 2012 Share Posted October 20, 2012 its so hard to guess noise without hearing them see if you can get a video of the noise .Rich. Quote Link to comment Share on other sites More sharing options...
levi Posted October 20, 2012 Share Posted October 20, 2012 Still got my squeal/squeak. Seems to be coming from a belt/pulley on the passenger side pretty close to the front of the car. Ill get a pic/vid when I can Quote Link to comment Share on other sites More sharing options...
vtec2011 Posted October 20, 2012 Author Share Posted October 20, 2012 I will try and upload a video of the noise soon hopefully. It only does the noise when the engine is warmed up when driving. Its not just a squeaky noise, it also sounds like somethings slack inside the gearbox.. Doesn't sound healthy Quote Link to comment Share on other sites More sharing options...
