Squeaky noise when accelerating?
vtec2011
Hi there.. Quite recently I start hearing this annoying noise when taping the accelerator pedal. Its also sounds like something is slack, making a sort of scraping noise. It only does it if the car is juddering (judders when its cold) or when pulling away from stand still. I think its either the inner drive shafts or the differential but not really sure. A couple months ago I have replaced the gearbox for a D16 gearbox, maybe its something to do with that? Any ideas or help will be great, thanks for reading :-P
I have a squeaky noise when i accelerate too! Im almost sure mine is a belt, but they are all pretty tight and in seemingly good condition.
Check your belts before you start playing with drivetrain i guess.. Mainly the alternator belt but your power steering etc could also be an issue. Get your head in the engine bay and have a listen to different parts and see if you can locate a noise with the car parked and engine idling.
I do have a squeaky alternator belt which will not stop! I even fitted a new one on and it still speaks.. I have found out what the noise is which is the diff. I think its knackered because there is a lot of play in both of the driveshafts. So that's going to be the gearbox off for the 3rd time.. banghead.gif1
  • 2 weeks later...
I will try and upload a video of the noise soon hopefully. It only does the noise when the engine is warmed up when driving. Its not just a squeaky noise, it also sounds like somethings slack inside the gearbox.. Doesn't sound healthy :roll:
