How do u remove the pillar plastics?
Nathan91
Hi, I had this problem on my in-laws aerodeck which I sold for him a while back, the rear spare wheel well was caused by dodgy gasket for rear light clusters and front footwell took ages to find but ended up being blocked drain holes in the bottom of the front door!
Might be worth checking yours.
Right ma headlignin an parcel shelf is dry which means tht ma roof and tailgate seal aint leakin - its 1000 % not coolant in the footwell - i even tasted it for sweetness lool - im gunna check the drain hole n rear light clusters now - jus 1 question .... How do i check the drain hole and where abouts is it?? Cheers guys :D
Iv jus checked the rear light clusters an the Gaskets (or what i presume to b the gaskets are dry) i did notice a lot of condensation inside the rear arches tho and it is wet on the top bit of thr spare wheeel well at thr sides - the carpet is as bit wet on both sides - i am quite stumped
  • 2 weeks later...
