Nemesis Posted January 1, 2013 Share Posted January 1, 2013 Hi everyone,As above my fog light is not working. I disconnected it and connected in to the driver side fog light connection and it still not working. Does this mean the bulb has fused?? If so, how do you change the bulb?Thanks Quote Link to comment Share on other sites More sharing options...
ryan.. Posted January 1, 2013 Share Posted January 1, 2013 sounds like the bulb might have popped yes. To remove you need to undo the 4 screws holding the bottom cover. These are notoriously hard to remove as the screws are made of chocolate. Once you take the plate off you unclip the spade connector then unclip the metal prong holding the bulb in place and pull the bulb out. The bulb is a H3Obviously fitting is the reverse Quote Link to comment Share on other sites More sharing options...
Nemesis Posted January 1, 2013 Author Share Posted January 1, 2013 Thanks pal Quote Link to comment Share on other sites More sharing options...
