weetec Posted January 26, 2013 Share Posted January 26, 2013 Hi peoples, looking to do my tracking. I understand gow to do the axlestand string methods but dont know the difference in front n rear wheel hub widths. Any help appreciated Quote Link to comment Share on other sites More sharing options...
noodels Posted January 26, 2013 Share Posted January 26, 2013 F 57.7=1465MMR 57.9=1470MM Quote Link to comment Share on other sites More sharing options...
weetec Posted January 26, 2013 Author Share Posted January 26, 2013 So if i set up 2 parallel strings either side say 100mm off the hubs front but 102.5 on the rear, would that be right Andy? With the wheels all the same size i think its safe to go off the centre caps? Quote Link to comment Share on other sites More sharing options...
noodels Posted January 26, 2013 Share Posted January 26, 2013 So if i set up 2 parallel strings either side say 100mm off the hubs front but 102.5 on the rear, would that be right Andy? With the wheels all the same size i think its safe to go off the centre caps? spot on mate get mine done at a shop for £0 for a test get a print out and >> go from there.Last hunter laser test 2months ago showed spot on, apart from n/s/f half a deg out on toeand was told dont worry about it,all top joints set with vernia gauge, just take measurments of oem centersand add +camber if that is required, and give it +1 or +2 mm for the drop dialled in and so it clears the arches start with +2 and go from there or pay £30+vat an adjustment Quote Link to comment Share on other sites More sharing options...
weetec Posted January 26, 2013 Author Share Posted January 26, 2013 Cheers Andrew Quote Link to comment Share on other sites More sharing options...
