Decat pipes and engine management light
Guest VTi-Stephen
Guest VTi-Stephen
I have a decat pipe in my vti and engine management is on due to the removal of the o2 sensor, i think! will the engine management light being on put the car into safe mode like it does in ep3's?
Doesn't your manifold have a O2 bung?
You really need an O2 sensor having a decat pipe and an exhaust. The car will run leaner from freeing up the exhaust, if an O2 sensor is in the exhaust the ECU increases fueling to compensate after a short adaptation period (longterm fuel trim).
