ek coilovers on mb6
arf4n1
ok ive read that they do fit, but what difference is there? the height at the back?
the spring rate will stay the same for front and rear as they are dual perch so that should be ok :)
yeah heard about the back and i have done a few searches which conflict each other..
so fronts are fine using the brake clip on the shock and the ek top mount nuts.
and rear are all bolt on?
Rears will fit but you will need spacers... On the bottom fork... As it a smaller damper on the rear, the highest adjustment may just be above the rear wheel.
