arf4n1 Posted March 31, 2013 Share Posted March 31, 2013 ok ive read that they do fit, but what difference is there? the height at the back?the spring rate will stay the same for front and rear as they are dual perch so that should be ok Quote Link to comment Share on other sites More sharing options...
WilkesyMB6 Posted March 31, 2013 Share Posted March 31, 2013 Do a search mate, its been covered a few times. The back does sit quite a lot lower do to the fitment and weight. Quote Link to comment Share on other sites More sharing options...
arf4n1 Posted April 1, 2013 Author Share Posted April 1, 2013 yeah heard about the back and i have done a few searches which conflict each other..so fronts are fine using the brake clip on the shock and the ek top mount nuts.and rear are all bolt on? Quote Link to comment Share on other sites More sharing options...
weetec Posted April 4, 2013 Share Posted April 4, 2013 Rears will fit but you will need spacers... On the bottom fork... As it a smaller damper on the rear, the highest adjustment may just be above the rear wheel. Quote Link to comment Share on other sites More sharing options...
spudley1988 Posted April 5, 2013 Share Posted April 5, 2013 Apparently EG coilovers fit effortlessley but cant remember if its on an mb6 or the other mb models. Have never tried just seen someone mention it on another forum. Quote Link to comment Share on other sites More sharing options...
