skitzma8 Posted April 14, 2013 Share Posted April 14, 2013 I need some help on fitting fog lamps on my civic MA8, basically I have looked behind the front bumper of my civic and I can see the mounting holes for the fog lamps, and where they should be its been capped off with plastic wich is easy to cut out that's no problem, But I've looked for wires for the fog lamps (as my car didn't have them as standard) and all I can find is a 3 pin box connector on each side, are these the right wires? And will the original fog lamp switch off another civic work on mine? Thanks Quote Link to comment Share on other sites More sharing options...
Povke1 Posted June 2, 2013 Share Posted June 2, 2013 Not sure for wiring, but 5 gen civics and MA8 share the same fog lights and holders, buton does fit also Quote Link to comment Share on other sites More sharing options...
