KieranEG6 Posted May 28, 2013 Share Posted May 28, 2013 Right can anyone enlighten me about Mb6 track rod ends. Would have thought they would be the same as EG/DC2/EK, but after a bit of part searching there seems to be a good bit of conflicting info. First line Parts claim they are the same part number as EK civic's. But then on here and on ADL Blueprint they seem to be different. I have ordered both Civic EK/EG/MB/MC that they have listed and the 45/ZS one from my motor factor just incase. Does anyone know the difference?Ball joint size/taper? Arm length? Can see there are 2 different shaped ones but does it really matter? Quote Link to comment Share on other sites More sharing options...
weetec Posted May 28, 2013 Share Posted May 28, 2013 i know this much on the EG you have an inner and an outer track rod end, but the MB6 there is the rack itself with a non-detachable inner and a replacable outer. Quote Link to comment Share on other sites More sharing options...
KieranEG6 Posted May 28, 2013 Author Share Posted May 28, 2013 i know this much on the EG you have an inner and an outer track rod end, but the MB6 there is the rack itself with a non-detachable inner and a replacable outer.Are you sure?Weird never seen that before. Every car I have worked on had replaceable inner tie rods. Also noticed both First line and ADL listed inners and outers. Just conficting part numbers to what fits which model. Quote Link to comment Share on other sites More sharing options...
