uneven tyre wear
Nav
Hey guys...I have this problem on my MB6..its puling to the left...i tried traking alignmnet wheel balance
none seem to pay off..
i just notice two weeks ago my driver side tyre is not wearing properly . the inside of the tyre (just by the tyre wall) has no thread left...now two weeks on i had a look again..... now the middle bit of the tyre has no thread left..but the bit on the side has thread left...u know wat i mean....i will upload a picture tmmorw to show u what i meant..
any idea whats the issue is..???
I checked the tyre pressure to see if it was over inflated but it was on 32Psi... :(:(
Could be lots of things have you damaged the suspension in anyway ie hit the crub or anything .if not you are best to have a good look at all the bushes front and rear if you can not see anything get it on a ramp or jack and check each wheel in turn for movement / play . if you still have nothing get a full 4 wheel geom check done . that way you will know were (as in witch corner) is giving you the problem . Rich.
