onejdmcivic1984 Posted February 13, 2014 Share Posted February 13, 2014 Heard a rumour that MG ZS 180 suspension is a good upgrade to the MB3 Oem suspension? Is that the case and by doing so does it lower the car a bit more? The Civic is a nice drive but feels like a boat around corners lol i want the civic to ride nicely and corner like my previous EJ9 civic which cornered well even on lowering springs.If the ride height is similar what springs can i use with the MG ZS suspension to lower it? Dont want coilies as this is my daily drive and cnt justify spending 600 on meister rsI also heard MG ZS ARBs make a world of diff? Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted February 13, 2014 Share Posted February 13, 2014 Yes mgzs kit is a good upgrade, you can use the 180 shocks with 120 springs for a slight lowering of around 15-20mm, or match the shocks to some decent lowering springs suited to the MB3. What you do depends on the size alloys you're planning on running, if 17's don't bother with lowering springs or you'll need to get the arches rolled. Bear in mind when buying springs that the shocks will lower it by 15mm as well. ARB is a great upgrade. Quote Link to comment Share on other sites More sharing options...
onejdmcivic1984 Posted February 13, 2014 Author Share Posted February 13, 2014 I wont be running nething bigger than 15" wheels.i like the fact theyre lighter and small in diameter so handle better. Thinking of swapping my wheels or purchasing some vti blades powdercoated in Gun Metal.i think after lowering it it will look great Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted February 13, 2014 Share Posted February 13, 2014 Sounds good, slam it then. 1 Quote Link to comment Share on other sites More sharing options...
spudley1988 Posted February 13, 2014 Share Posted February 13, 2014 Def need lowering springs with them. I tried just mgzs shocks and springs on my old mb3 and it sat mega high lol. Works better on the mb6 with just full standard set up as B series weighs more. Once lowered tho great budget modification. Quote Link to comment Share on other sites More sharing options...
onejdmcivic1984 Posted February 14, 2014 Author Share Posted February 14, 2014 WHat lowering springs do i buy though - ones for civic or ones for mg zr? Or does it make no difference? Whats the most mg zs standard shocks can take drop wise? Quote Link to comment Share on other sites More sharing options...
onejdmcivic1984 Posted February 14, 2014 Author Share Posted February 14, 2014 Was thinking of putting an integra type r engine in or h22 from a prelude vti Quote Link to comment Share on other sites More sharing options...
onejdmcivic1984 Posted February 14, 2014 Author Share Posted February 14, 2014 Anyone got a pic of their mb3 on MG ZS suspension (theyre shocks and springs)?Wondering if the 2cm or so drop would make a world of difference in terms of stance? Quote Link to comment Share on other sites More sharing options...
Krzys Posted February 14, 2014 Share Posted February 14, 2014 On 2/14/2014 at 3:47 AM, onejdmcivic1984 said: WHat lowering springs do i buy though - ones for civic or ones for mg zr? Or does it make no difference? Whats the most mg zs standard shocks can take drop wise?If you get the MGZS180 shocks I think Eibach lowering springs for the MB3 would be fine! Any drop by lowering spring will shorten the lifespan of any shock absorber by the way! But because the MG ones are a bit lower before adding springs it's a bit better. Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted February 14, 2014 Share Posted February 14, 2014 On 2/14/2014 at 3:47 AM, onejdmcivic1984 said: WHat lowering springs do i buy though - ones for civic or ones for mg zr? Or does it make no difference? Whats the most mg zs standard shocks can take drop wise? When I had mgzs I had Eibach springs for an MB and that's what I'd recommend. Stick with -40mm that should give you a combined drop of 55-60mm, which is nice. On 2/14/2014 at 3:48 AM, onejdmcivic1984 said: Was thinking of putting an integra type r engine in or h22 from a prelude vti If and when you do that I would think about investing in coilovers. On 2/14/2014 at 4:03 AM, onejdmcivic1984 said: Wondering if the 2cm or so drop would make a world of difference in terms of stance? Not a massive amount, no. If you use the standard 180 springs they will be under-compressed due to the engine weight difference. Quote Link to comment Share on other sites More sharing options...
