shaft32 Posted January 27, 2010 Share Posted January 27, 2010 is it a good idea putting lowering springs on used standard shocks.going down 30, 40mm???? Link to comment Share on other sites More sharing options...
mb6vti Posted January 28, 2010 Share Posted January 28, 2010 IMO no as you will seriously shorten the life of the std shocks. Depends on the age of the shocks - if less than 100k then should be ok but will eventually need to upgrade. However if shocks are past 100k then my advsied would be to change both shocks and springs. Also the standard shocks are designed not to be used with shorter progressive springs. Link to comment Share on other sites More sharing options...
