Krzys Posted March 5, 2014 Share Posted March 5, 2014 On 3/5/2014 at 12:40 PM, yellowUmberella said: You can't run antilag on roller bearing turbos though.. It'll be phucked. The shafts aren't built to withstand the pressure, a normal shaft on a non-roller turbo are thicker and tougher as they centralise the propeller unlike the roller bearing ones which are spaceredTurbo got VTEC, yo!You probably wouldn't want to anyway, my understanding is it's designed to spool up quicker anyway? On 3/5/2014 at 12:37 PM, NIKH25 said: The VV turbos kind of run like that, it's almost like a smaller turbo inside a bigger turbo if you get what I mean.Yeah that makes sense! Sounds cool yet complicated, more to go wrong! Quote Link to comment Share on other sites More sharing options...
yellowUmberella Posted March 6, 2014 Share Posted March 6, 2014 On 3/5/2014 at 12:48 PM, Krzys said: You probably wouldn't want to anyway, my understanding is it's designed to spool up quicker anyway?Yeah that makes sense! Sounds cool yet complicated, more to go wrong!Pumps more fuel in, the turbo compresses the vapourised petrol this is then forced into the cylinder and when it mixes it goes bang harder. The seals and bearing seals are made from a high temp silicon iirc and silicon and petrol don't mix nor do they like the high amount of pressure being exerted on the shaft which run harder and faster as its basically a hot rotating explosive aerosolOur 180 had antilag on the omex system, had a switch on the dash to turn it on. When it was activated once the police turned up. Armed. Though it was gunshots. 3 Quote Link to comment Share on other sites More sharing options...
Krzys Posted March 6, 2014 Share Posted March 6, 2014 On 3/6/2014 at 12:41 AM, yellowUmberella said: Pumps more fuel in, the turbo compresses the vapourised petrol this is then forced into the cylinder and when it mixes it goes bang harder. The seals and bearing seals are made from a high temp silicon iirc and silicon and petrol don't mix nor do they like the high amount of pressure being exerted on the shaft which run harder and faster as its basically a hot rotating explosive aerosolOur 180 had antilag on the omex system, had a switch on the dash to turn it on. When it was activated once the police turned up. Armed. Though it was gunshots. Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted March 6, 2014 Share Posted March 6, 2014 On 3/6/2014 at 12:41 AM, yellowUmberella said: Pumps more fuel in, the turbo compresses the vapourised petrol this is then forced into the cylinder and when it mixes it goes bang harder. The seals and bearing seals are made from a high temp silicon iirc and silicon and petrol don't mix nor do they like the high amount of pressure being exerted on the shaft which run harder and faster as its basically a hot rotating explosive aerosolOur 180 had antilag on the omex system, had a switch on the dash to turn it on. When it was activated once the police turned up. Armed. Though it was gunshots. Armed police, put the exhaust down or we will shoot you. 1 Quote Link to comment Share on other sites More sharing options...
Krzys Posted March 6, 2014 Share Posted March 6, 2014 On 3/6/2014 at 10:18 AM, NIKH25 said: Armed police, put the exhaust down or we will shoot you. I think in Nottingham that would be quite legit 1 Quote Link to comment Share on other sites More sharing options...
