civicturbo79 Posted February 13, 2010 Share Posted February 13, 2010 I wish i could be more help mate , but it is really hard with out seeing the car . Keep us posted mate . Rich. Link to comment Share on other sites More sharing options...
danxs Posted February 13, 2010 Author Share Posted February 13, 2010 no worries, its hard even with seeing the car as its intermittent most days which is annoying. il try sensors later on today Link to comment Share on other sites More sharing options...
jonnyricer Posted February 19, 2010 Share Posted February 19, 2010 any joy on this?????? Link to comment Share on other sites More sharing options...
jalesi2001 Posted February 20, 2010 Share Posted February 20, 2010 I'll be suprised if its sensor related, (apart from the ones in the dizzy), as you would get an engine management light on. There are 2 parts to the main relay, one that runs the fuel pump, and one that runs the spark side of things, and also the igniter commonly causes starting problems on our cars, it sounds like one of them bud.You haven't got an after market alarm fitted have you?? Link to comment Share on other sites More sharing options...
danxs Posted February 23, 2010 Author Share Posted February 23, 2010 ive got a cat1 fitted since the car was new. never had any problems with it thoughonce the car has initially started its fine. i think it may be down to a weak spark? i need another known working dizzy to check though. Link to comment Share on other sites More sharing options...
stoocake Posted February 23, 2010 Share Posted February 23, 2010 Sounds dizzy related to me too - check the advance is set correctly. Wet plugs after it's been running could mean too much retardation on the timing. The whole dizzy assembly is held on with 3 bolts, which can be loosened and the whole dizzy rotated - have a quick read up on it before you do anything. Link to comment Share on other sites More sharing options...
danxs Posted February 23, 2010 Author Share Posted February 23, 2010 dizzy timing is fine, nothing has changed as it was set to factory settings and the ecu should kinda sort it out a little if it needs toi guess it may be the spark not being strong enough on the ignitor and too much fuel from the cold start for the weakened spark maybe? Link to comment Share on other sites More sharing options...
