Hash1988 Posted August 16, 2014 Share Posted August 16, 2014 Does anyone know how to adjust the clutch on an mb2 as need to adjust a bit lower.Cheers. Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted August 16, 2014 Share Posted August 16, 2014 You can adjust pedal slightly. Using nut under dash at the top of the pedal. It's obvious when you look. But you should always have free play on the pedal. Never have it making contact when no pressure applied. If your bite point is out of the ordinary then you could either have a hydraulic issue or some part of the clutch or release fork is worn. 2 Quote Link to comment Share on other sites More sharing options...
Hash1988 Posted August 17, 2014 Author Share Posted August 17, 2014 OK cool thanks for the reply il have ago at it see what's going on down there. Quote Link to comment Share on other sites More sharing options...
ashy Posted May 3, 2015 Share Posted May 3, 2015 Is a 1999 Civic 1.4 5 door hatchback also an MB2? As the car ive just picked up for my brother has lots of free play on the clutch pedal Quote Link to comment Share on other sites More sharing options...
