Sega Posted March 6, 2010 Share Posted March 6, 2010 Im going to give rattle canning a go, it may not be perfect but itll do for now.Roughly what do I do to get it right and how much primer and paint do I need for possibly 2 bumpers and of course my Custom grill when its made?Thanks in advance Link to comment Share on other sites More sharing options...
Sega Posted March 7, 2010 Author Share Posted March 7, 2010 Anyone? Link to comment Share on other sites More sharing options...
civicturbo79 Posted March 7, 2010 Share Posted March 7, 2010 Rattle can are not really the way but i understand money is tight at the min . you will need to get the bumper repaired if it needs any repairs and key the bumper with a red scotch pad , pre clean the bumper off to remove any grease and dirt , then plastic prim any bear plastic areas , then prim the bumper , once dry , flat the bumper with 500 grit wet and dry paper and spary the colour on i would say 2 to 3 can per bumper . you want to do nice light coat allowing the paint to dry between each coat , keep doing this till you have got the paint to cover . Then on to the clear coat , you want at half coat let it dry for 10 mins and then 2 full coat to get a finish . heat is a big part in this process . then you are done . Rich. Link to comment Share on other sites More sharing options...
Sega Posted March 7, 2010 Author Share Posted March 7, 2010 What sort of size can are we talking? I can get primer in 500ml but Carmen Red I can only get as 150ml on the cheap. Link to comment Share on other sites More sharing options...
civicturbo79 Posted March 7, 2010 Share Posted March 7, 2010 This is the thing , its hard to say it just depends how well the paint covers . Rich. Link to comment Share on other sites More sharing options...
Sega Posted March 7, 2010 Author Share Posted March 7, 2010 Ok, Ill see what Halfrauds has got in stock and work out roughly the Colour from how much primer I get through.Thanks Rich Link to comment Share on other sites More sharing options...
