GBs MB6 mods start here......(now with pics)
GB.
bargan what new?????looks new good, now arches filled nice, mud flaps next? done my fronts take back ones off soon mgzs stuts spings now decat resonator removed with drain pipe same length as standard to lower inner front wing sounds good!!!cold air!!!might take centre box out next?? 8-) 8-)oh yes and reset ecu!!!!!!!
like the blue calipers mate 8-)8-)
  • Replies 114
run car uproad till hot/normal temp
come back home take ecu fuse out time 10 mins
replace fuse run 10 mins
turn off 2 mins
restart engine
job done mate!!!!!!!!!!!! 8-)8-)
Where is the fuse, fuse box or under bonnet?
Ok lets go through this dummies style
drive car till hot/normal temp,
come back home take ecu fuse,leave out for 10 mins (I'm presuming you turn engine off before removing fuse?)
replace fuse run engine for 10 mins not touching throttle
turn off 2 mins not touching throttle(I'm presuming that means leave off for 2 mins before restarting)
restart engine
Reading this it sounds as if the ecu has a closed loop learning area around idle rpm,would that be correct?
