Damage on top of front camber arm?
jdmsaq
I recently had my front camber arms fitted and adjusted accordingly also tracking done, however something has started to poke upwards and i do not know what is causing this.. Can someone help..
Below is a picture of damage being caused (that is drivers side) same is starting to happen on passenger side..
Lower your car they said.......
as above...
Its to low and its damaged the top chassis plate :x have heard about this but not seen the effects.
Not good..
What camber kit was used ? :?:
as above...
Not good..
Looks like im going to have to raise the car by the looks of it..
D2 camber kit was used..
Below are additional pictures..
Guest jimbob738
Holy Jesus, i am guessing that the camber arms are smashing fook out of the top of the wheel arch :-o i would maybe get the stock ones back on before its beyond repair, cant believe your 70mm lowered kinda what you got to expect isn't it?
