Dave Posted August 12, 2015 Share Posted August 12, 2015 On most the Honda civics to get abs codes you basically have to bridge the 2 pin connector. But with the civic 5 doors 96-00 you need to bridge 2 pins in the 5 pin data link connector to get abs trouble codes. The following picture shows which 2 pins need to be bridged to get the abs light blinking. The red marker is supplying 12v so don’t bridge the wrong pins otherwise you might fry something.You can then look up which code it is. 1 Quote Link to comment Share on other sites More sharing options...
Chandler Posted August 12, 2015 Share Posted August 12, 2015 here you go @Dave a little how to in there aswel!! will help people out to get the right code 1 Quote Link to comment Share on other sites More sharing options...
Dave Posted August 13, 2015 Author Share Posted August 13, 2015 Excellent! Cheer mate! Quote Link to comment Share on other sites More sharing options...
Chandler Posted August 13, 2015 Share Posted August 13, 2015 no problem, might be better to upload to photobucket so it'll be a bigger picture instead of people clicking on it to enlarge Quote Link to comment Share on other sites More sharing options...
