ABS FAULT CODES AND HOW TO GET THEM
Dave
On most the Honda civics to get abs codes you basically have to bridge the 2 pin connector. But with the civic 5 doors 96-00 you need to bridge 2 pins in the 5 pin data link connector to get abs trouble codes. The following picture shows which 2 pins need to be bridged to get the abs light blinking. The red marker is supplying 12v so don’t bridge the wrong pins otherwise you might fry something.
You can then look up which code it is.
  • Dave unpinned this topic
