1.8vti Posted April 6, 2010 Share Posted April 6, 2010 when replace sump gasket is it need remove the monifold ?thxAki Link to comment Share on other sites More sharing options...
civicturbo79 Posted April 6, 2010 Share Posted April 6, 2010 Yes you will need to remove the manifold and down pipe . Rich. Link to comment Share on other sites More sharing options...
1.8vti Posted April 6, 2010 Author Share Posted April 6, 2010 so need the new gasket for the monifold as well?thxAki Link to comment Share on other sites More sharing options...
MBBREAKERS Posted April 7, 2010 Share Posted April 7, 2010 no the gasket for the manifold is a kinda metal plate won't need one of those when you change the gasket , clean the sump and bottom of the block so there is no oil there , and put a small beed of silcone on the sump to hold the gasket in place as you put it on as can be a right fiddley little bitch Link to comment Share on other sites More sharing options...
Sega Posted April 8, 2010 Share Posted April 8, 2010 I agree its fiddly, I had to change my sump as some tw@t who serviced my car before I got it over tightened the plug and had caused the thread to strip.Make sure you have plenty of penatrating fluid to hand as well as the bolts can be stiff. I got away with just removing the down pipe but then it may be different on the B18. Link to comment Share on other sites More sharing options...
1.8vti Posted April 9, 2010 Author Share Posted April 9, 2010 do you mean WD40? Link to comment Share on other sites More sharing options...
jalesi2001 Posted April 10, 2010 Share Posted April 10, 2010 Yeah WD-40 will do for the manifold bolts Aki! Make sure you give them a good soak!! Link to comment Share on other sites More sharing options...
1.8vti Posted April 11, 2010 Author Share Posted April 11, 2010 yes master . what can i use to clean the engie oil? can i use brake cleaning? Link to comment Share on other sites More sharing options...
blacksport01 Posted April 11, 2010 Share Posted April 11, 2010 Yea brake cleaner will be fine or just tissue. Its just to make sure the gasket has a clean surface to go onto Link to comment Share on other sites More sharing options...
