Got a abs fault which is driving me crazy. Got the car with the abs light on, did the paper clip test which came up drivers rear snr fault. Tonight I changed the snr for a known good one. Tried switching the ignition on 4 times and the light went out as it should each time. I then went into the house for a hour and when I came back out then tried it again and the abs light is back on. Checked the connection of the snr which is all good and also fuses/relays. Drove the car round the block and it stays on?
Will try paper clip test tomorrow again as phone ran out of battery so couldn't get procedure. I'm I missing something easy here? Should I just rip the bulb out and be done with it?
J18bey
1 answer to this question
