P30 ECU instead of p28
Patrix
Hi all,
I'm planning to do a mini-me on my 1.5 Vtec-e
I've read a lot about it but two things I'm not sure of, will it run (good) with a P30 ECU from a Civic del sol, or do I need the P28 ECU?
And a adjustable cam gear is not necessary because I'm not changing cam only but the complete head?
I'm able to buy a complete D16Z6 engine, costs are low because of oil consumption, engine has run 130 Miles.
Regards,
Patrick
Another option I'm thinking of...
Is it possible to engage the VTEC from a D16Z6 head with the wire that's activating my current VTEC-E solenoid?
I would say yes, only the VTEC will be activated at 3000 RPM (sounds like fun :-D) because that's the current RPM to activate the four extra valves right now....
