EKLewis Posted July 14, 2010 Share Posted July 14, 2010 Ok guys, the time is almost here for me to get some coilovers for my Aerodeck, i am struggling to find any to fit though, can anyone reccomend/advise where to go for them and what ones? I have save up about £600 so can get some pretty good ones I hope. My car is a W plate 2000 1.6SE if that helps??Cheers Link to comment Share on other sites More sharing options...
knightmaric Posted July 19, 2010 Share Posted July 19, 2010 Try meisterr.I know he has a kit designed for regular MB's you could contact him about the aero =]His name is jerrick and he's an awesome guy. Link to comment Share on other sites More sharing options...
james Posted July 19, 2010 Share Posted July 19, 2010 ok look at todays post you will find a answer Link to comment Share on other sites More sharing options...
knightmaric Posted July 19, 2010 Share Posted July 19, 2010 Calm down I was in work whn I wrote that and the site doesn't work properly on our crappy old pcs.Will have a look now. Link to comment Share on other sites More sharing options...
uzy Posted July 21, 2010 Share Posted July 21, 2010 If you are after coilovers then fitment wise, EK coilovers fit perfectly. As the M civic has slightly longer shocks you will have a slight increase in "drop". So to speak. MisterR coilovers are designed for hondas. A couple of my mates have them and rate them very well. Also for that price you could get some BC coilovers or some second hand cusco. Hope this kinda helps you out Link to comment Share on other sites More sharing options...
EKLewis Posted July 21, 2010 Author Share Posted July 21, 2010 Cheers for all the positive replies guys, I'm very tempted by the Meister R's, they seem very cheap but very popular here and on civiclife. I didn't know the ek shocks where shorter, does this mean even with the coilovers on their highest setting it'll still sit lower? Link to comment Share on other sites More sharing options...
uzy Posted July 21, 2010 Share Posted July 21, 2010 They are only 25mm shorter than the M civic ones nothing really to worry about. I ran EK coilover on my MB and it was fine but I did run mine as low as I could possibly go. I am going to get BC coiliovers for my car and I can choose the spring rate I want and damping settings. I wouldn't worry about the difference in size in the shock length. It just saves you going lower and you can keep the spring in tension as well Link to comment Share on other sites More sharing options...
EKLewis Posted July 21, 2010 Author Share Posted July 21, 2010 Yeah boi, I saw your car it was dumped as anything, super low :). I wanna be tucking tyre on the front and a few mm higher at the back just to give it a little rake And yeah I hear very good things about BC's from my friend who works at Rogue, they use them on all their track cars. Out of interest, how much is it costing to have that setup for you? Link to comment Share on other sites More sharing options...
uzy Posted July 22, 2010 Share Posted July 22, 2010 Am sure a place in falkirk called pro grip do a fast road setup for £60. But correct me if I am wrong. I would advise to go for handling and not looks. I had mine setup just to be low and it did handle good but not to full potential. Link to comment Share on other sites More sharing options...
Sean_GT Posted July 22, 2010 Share Posted July 22, 2010 They are only 25mm shorter than the M civic ones nothing really to worry about. I ran EK coilover on my MB and it was fine but I did run mine as low as I could possibly go. I am going to get BC coiliovers for my car and I can choose the spring rate I want and damping settings. I wouldn't worry about the difference in size in the shock length. It just saves you going lower and you can keep the spring in tension as wellwhat ek shocks did you buy mate. just so i know what to search for, for my mb6 Link to comment Share on other sites More sharing options...
