Hello all,
I am writing this topic hoping that someone can help me out.
I have a MB3 from 1997 that is in my family since.
I am now, slowly, trying to bring it back to a newer state. I have the manuals, the tools and the love to work on it and everything was working well until now.
I have changed the front upper arm, front shocks, outer steering, ball joints, all front bushings at lastly cv boots. Note that the CV boots were changed because they were starting to rip but had no holes.
Now that I have changed everything it started to make a noise while turning the wheel left and right. while stopped and while moving.
It is not the clicking noise that bad outer cv makes as the bearings are bad. It just sounds like a plastic drag sound or a 1 time grind. It is very strange. Almost as when you it a bump whitout shocks.
What can it be? where did I failed or what should I check? I know there is a small loose in the inner steering but just a small one, not even 1 inch, that was already before all the changes I made.
Also I note that the cv axle while in jack stands goes in and out a bit but they are both locked in the transmission and in the wheel. I do not know if it is normal. Can someone help me? I am just sad as I changed everything and know I have a sound that I had not before. Thank you all for the support you provide in this forum.
Pedro
Question
Senpas
Hello all,
Pedro
4 answers to this question
