prezes Posted September 3, 2010 Share Posted September 3, 2010 but why is it so random then? it does not happen every time. Link to comment Share on other sites More sharing options...
tontvti Posted September 3, 2010 Share Posted September 3, 2010 On the Hondata website they suggest that Honda puts really low ignition timing in low down in the rev range on vtect engines to reduce torque steer.Look at the jump up on low down torque when they added some timing in on a stock 97 Type Rhttp://www.hondata.com/dyno97typer.html Link to comment Share on other sites More sharing options...
GB. Posted September 3, 2010 Author Share Posted September 3, 2010 That's interesting, but what software do I need to do that? Because I'm sure if I just turn the dizzy old school style it will be to much in the upper rev range. ... I'm not familiar with how the ECM works on these, but I would imagine it has a learning loop area in its range which sets the St failure to 14.7-1 based on O2,air temp,engine temp etc, now if the conditions are right/wrong the ECM will to lean it off some more on the whole map, when its already lean in certain areas it will create a flat spot. Link to comment Share on other sites More sharing options...
noodels Posted September 3, 2010 Share Posted September 3, 2010 http://www.megamanual.com/index.htmlmore parameters needed perhaps? the smoother the curve the better maybe TPS needs looking @ volt metre ect rising on opening throttle> see volts deilivered to ecm/=fuel deilivery@low opening,=too much fuel /not enough fuel?=splutterget that voltmeter out Graham hot/cold diffrence? ECT/IAT all to be checked!!while you are in the area as well as injectors just put My intake back on maybe, just maybe? undo your last modification to see if problem still exists Link to comment Share on other sites More sharing options...
Moe Posted September 3, 2010 Share Posted September 3, 2010 at the moment im using a chipped P72 ECU, iv also got a chip burner so im going to be playing with the fuelling and ignition low down. Link to comment Share on other sites More sharing options...
