Flat spot
GB.
  • Replies 43
That's interesting, but what software do I need to do that? Because I'm sure if I just turn the dizzy old school style it will be to much in the upper rev range. ... I'm not familiar with how the ECM works on these, but I would imagine it has a learning loop area in its range which sets the St failure to 14.7-1 based on O2,air temp,engine temp etc, now if the conditions are right/wrong the ECM will to lean it off some more on the whole map, when its already lean in certain areas it will create a flat spot.
http://www.megamanual.com/index.html
more parameters needed perhaps? ;)
the smoother the curve the better ;)
maybe TPS needs looking @ volt metre ect rising on opening throttle> :idea: see volts deilivered to ecm/=fuel deilivery@low opening,=too much fuel /not enough fuel?=splutterget that voltmeter out Graham :idea: hot/cold diffrence? :idea: ECT/IAT all to be checked!!while you are in the area 8-) as well as injectors ;)
just put My intake back on :idea:;)
maybe, just maybe? undo your last modification to see if problem still exists :idea:
