thebusofwoe Posted December 20, 2010 Share Posted December 20, 2010 Hi guys and great job on the forum. I am after info on exhaust and engine harness. I am wanting to swap a b16 motor into my mc1 aerodeck. I know people will ask why a b16 and the answer is that i love the engine and i want something different. Anyway i am after info on exhaust compatibility and also wether i could use the b18 engine loom as it would be easyer i guess as the aerodeck 'vti' ect. Also does anyone know of places to buy bolt on exhausts for the aerodeck?Any help would be great.Thanks Link to comment Share on other sites More sharing options...
johngreen537 Posted December 20, 2010 Share Posted December 20, 2010 There are a few dfferences in the loom mate. B18 uses a IAb in the manifold, which also has a sensor.If you buying an engine and box to do a conversion, your best bet is to use a B18 with a S80 (INtegra Type R) gearbox, or the Y21 box from a 1.6 VTi.That way you get the extra bit of grunt from the B18, but the closer ratios of the DC2 / B16 box! Link to comment Share on other sites More sharing options...
Dave Posted December 21, 2010 Share Posted December 21, 2010 Hi Mate. You can get exhausts for the deck from mongoose, Powerflow etc and a few others. Not sure on off the shelf though, as these are all custom built exhausts from the above.For the engine swap, there will be a few issues with the wiring on either of the B's. You'll need the ecu for the B16 aswell unless your going for a programable ecu, as it's a different set up altogether from the B18. I like the idea of the B16 in the deck! It's deff do-able, as its been done countless times in ej9 and eg civics. A good autospark will be able to wire the lot up for you. Have you already got the engine? Link to comment Share on other sites More sharing options...
Guest Posted December 24, 2010 Share Posted December 24, 2010 I'm just doing a n18 swap onto my mc1 its with mechanic at the mo. Once I have wiring sorted ill put up a thread in the how to section. Also just so you know mgzs back boxes fit our cars. I have a sportex one in the shed I bought as a temp before I bought my full system. Has 4" tip if your interested you can have it for 30 quid plus pnp Link to comment Share on other sites More sharing options...
