running weak?
nathan123487
i changed my spark plugs today.. my uncle was with me as he has tools and i dont and he looked at my spark plugs and said.. yep they need changing and the cars running weak...... could this of been because the air filter was dirty(but not that bad) and not enough air was getting in for the ecu to put as much fuel in? or is there a problem here some where?
we changed it all yesterday ( exept the fuel filter ironically which was just sat in the boot) so i am going to attempt it myself this afternoon (wish me luck) ,.... i know its off topic but however desinged the place for the oil filter to go needs shooting
cheers guys
ha ha ha i understand about the oil filter mate right balls try the timing belt then you will have headach
i have made a how to on the fuel filter have a look
dude i just changed it + all the acc belts omg im weak from runing into problems
anyway make sure you tighten up the bango bolts good and tight as i have experienced leaking twice
make sure you check for leaks man with the car running very important
