johngreen537 Posted January 26, 2011 Share Posted January 26, 2011 4-1 for me too, I'm a revver With a VTEC, you have to MAKE it go, so keep your foot planted James, EK9 Cams are a decent mod Problem is getting the clearance settings correct Link to comment Share on other sites More sharing options...
james Posted January 26, 2011 Share Posted January 26, 2011 hhhmmm explain mr green Link to comment Share on other sites More sharing options...
johngreen537 Posted January 26, 2011 Share Posted January 26, 2011 EK9 Cams will bolt straight on, but as the EK9 has higher compression / double valve springs, reatainers etc the valve clearance settings will need to be figured out....B16/B18 have different (only slightly) valve clearances. When you get cams re-ground, they come back with the correct figures to tell you what to set the clearances to. Not sure how you'd work out what to set them as though! Link to comment Share on other sites More sharing options...
james Posted January 26, 2011 Share Posted January 26, 2011 youd pick a nice set up second hand cheap enough like Link to comment Share on other sites More sharing options...
HONDACIVIC Posted January 27, 2011 Author Share Posted January 27, 2011 about the manifolds wich will give beter sound i mean i want my car to have a nice vetec roar and i dnt want it to sound like a subaru or sumat and can anyone here the crossovr at 5800rpm on the mb6 like the b16 or jus at 4500rpm Link to comment Share on other sites More sharing options...
Aky Posted January 27, 2011 Share Posted January 27, 2011 Changing inlet manifold to skunk2 or similar with give you more vtec sound. Youl also hear vtec at 4500. Link to comment Share on other sites More sharing options...
