belfastlad123 Posted March 15, 2011 Share Posted March 15, 2011 is it a hard job to change the rubbers need mine done .how much are they off honda ?? Link to comment Share on other sites More sharing options...
southwestmb6 Posted March 15, 2011 Share Posted March 15, 2011 just to update ma situation, i had to chnge the rubbers for the window allighnment and got the window correctly postiond, but the window still moves forward and backwards, it goes up and down without coming out of postion.sounds like play in the mechanism . Take off your door trim panel and check its not the window channels first as they can be adjusted. These were always a pain from new. Link to comment Share on other sites More sharing options...
southwestmb6 Posted March 15, 2011 Share Posted March 15, 2011 is it a hard job to change the rubbers need mine done .how much are they off honda ??Cant help with price , but quite easy to change rubber seal . wd40 or ideally silicone /rubber lube of some kind - spray this to new seal and old one . Wind down window pull out old seal , once lubed slide new seal down channels making sure it slides into glass . ( you might have to raise glass up and down to assist you) . Good luck. Link to comment Share on other sites More sharing options...
belfastlad123 Posted March 15, 2011 Share Posted March 15, 2011 i thought you had to pull the door card and all off and do it from inside aw right just push it down and put window up and down to work its way in .cheers mate Link to comment Share on other sites More sharing options...
scottravenhill Posted March 16, 2011 Share Posted March 16, 2011 My window slows down and creaks when its half way up as if its going to crack :lol: Link to comment Share on other sites More sharing options...
johngreen537 Posted March 16, 2011 Share Posted March 16, 2011 Sounds like you need some silicone grease in the runners Scott! Link to comment Share on other sites More sharing options...
belfastlad123 Posted March 16, 2011 Share Posted March 16, 2011 mine goes like that a bit .i just spray load of aesy glide down it every few weeks . Link to comment Share on other sites More sharing options...
safyanali786 Posted March 17, 2011 Author Share Posted March 17, 2011 is it a hard job to change the rubbers need mine done .how much are they off honda ??i gt da rubbers from a local scrap yard, gd condition for a £5, n i gt a mechanic to do the job, Link to comment Share on other sites More sharing options...
safyanali786 Posted March 17, 2011 Author Share Posted March 17, 2011 you have adjustment for the glass m8 . When looking at the door frame you will see 2 elongated holes with either 8mm or 10mm bolts undo these and grab the glass hold , keep the glass tight towards the rear of the frame , you should see the bolts move and retighten . Retry the operation moving window slowly checking ok . If the glass still comes out try adjusting again . (lub the rubbers helps) .When you take the door trim off spray some water on the glue that holds the weather membrane on as this makes this nightmare stuff non sticky .Good luck . (the mechanism can bend as well and really then is unserviceable.)when ma mechanic was putting the rubbers in, he kept havin the problem of the window kept coiming out of place, so had 2 gt othrs to secure it in place and thn screw the window to the motr, took about just under an hour for such a small job. the wondow still moves slightly out nw but doesnt cum out of the rubbers, also i checked the old rubbers and it had cuts in thm. Link to comment Share on other sites More sharing options...
scottravenhill Posted March 17, 2011 Share Posted March 17, 2011 i tried spraying silicon lube in there before, maybe i didnt use enough. Link to comment Share on other sites More sharing options...
