safyanali786 Posted March 3, 2011 Share Posted March 3, 2011 hi i am having problems with my driver side window, i recently put a new motor in. but the window doesnt stay in the rubbers when going up, it moves slightly out of place. dont know what to do!please help. summers coming up and dont really wana drive with the window up when the weathrs nice. Link to comment Share on other sites More sharing options...
simpo Posted March 3, 2011 Share Posted March 3, 2011 i would say the regulator is on its way out Link to comment Share on other sites More sharing options...
safyanali786 Posted March 3, 2011 Author Share Posted March 3, 2011 regulator?? i got a spare window, would that help? Link to comment Share on other sites More sharing options...
simpo Posted March 3, 2011 Share Posted March 3, 2011 no mate window wouldnt help. the regulator is the mechanism the window sits on Link to comment Share on other sites More sharing options...
safyanali786 Posted March 3, 2011 Author Share Posted March 3, 2011 that the motor isnt? i replaced it but hving the same problem? :S Link to comment Share on other sites More sharing options...
beastgtir Posted March 3, 2011 Share Posted March 3, 2011 think the window has come off the track Link to comment Share on other sites More sharing options...
simpo Posted March 3, 2011 Share Posted March 3, 2011 yeah motor is attached to it. was it brand new or second hand. just double check you have fitted it all properly make sure all bolts are in the right place and window is in the runner properly Link to comment Share on other sites More sharing options...
southwestmb6 Posted March 3, 2011 Share Posted March 3, 2011 you have adjustment for the glass m8 . When looking at the door frame you will see 2 elongated holes with either 8mm or 10mm bolts undo these and grab the glass hold , keep the glass tight towards the rear of the frame , you should see the bolts move and retighten . Retry the operation moving window slowly checking ok . If the glass still comes out try adjusting again . (lub the rubbers helps) .When you take the door trim off spray some water on the glue that holds the weather membrane on as this makes this nightmare stuff non sticky .Good luck . (the mechanism can bend as well and really then is unserviceable.) Link to comment Share on other sites More sharing options...
belfastlad123 Posted March 7, 2011 Share Posted March 7, 2011 sounds a bit like my window mate when if its not greased up it twists anticlockwise (best way to explain it lol )every few weeks i just spray some easy glide on it .is that the way yours is going .hope that helps Link to comment Share on other sites More sharing options...
safyanali786 Posted March 12, 2011 Author Share Posted March 12, 2011 just to update ma situation, i had to chnge the rubbers for the window allighnment and got the window correctly postiond, but the window still moves forward and backwards, it goes up and down without coming out of postion. Link to comment Share on other sites More sharing options...
