B16a2 cams
Grant
Will these fit the c4?? and will there be a performance gain? i can get hold of some cheap, thats all.. if so are there any other mods to go along with them?? i have already done skunk2 inlet and new exhaust headers..
well im sure that ive read somewhere that they are a higher lift and slightly longer duration, no idea where i would get the specs from though?????
A link in James post eventually led to this!
Following cam measured with 0mm of lift:
Civic Si(1999 Spec)
Int-265 dur. / 10.5mm lift
Exh-267 dur. / 9.6mm lift
Integra GS-R
Int-274 dur. / 10.7mm lift
Exh-276 dur. / 9.6mm lift
As its a US site,
B16A2 in Civic Si (Same almost as UK Spec EK VTi)
B18C4 in Integra GSR, same engine as UK MB6 VTi, different management tho!
I'd say from that, no point going for standard B16A cams..
