stubrun Posted May 20, 2011 Share Posted May 20, 2011 i want a badgeless gril, just dont know where to get one from. As for the lip its all getting colour coded soon and im gettin some import size plates made for it when i go to the japshow.#just make one mate, cut out the plastic and put some mesh in it, i am sure there is a how to on here. stuart Link to comment Share on other sites More sharing options...
Guest Posted May 20, 2011 Share Posted May 20, 2011 i dont like mesh mate sorry to offend. i like standard looking grills, just look better with no badge Link to comment Share on other sites More sharing options...
Guest Posted May 26, 2011 Share Posted May 26, 2011 little update people. baged myself a set of hid's today and fitted them at work on my lunch break. Link to comment Share on other sites More sharing options...
keel Posted July 8, 2011 Share Posted July 8, 2011 Hi, can you post some pictures how you've mounted the fog lights and how you've wired them (or at least some ideas).And one advice - HIDs without focusing lenses and on stock headligths (with the fresnel condeser) are really blinding for oncoming vehicles. Link to comment Share on other sites More sharing options...
Errordeck Posted July 8, 2011 Share Posted July 8, 2011 This looks really good! I've been wanting to do this for quite a while now!How did you get the glass of the headlight? i've heard quite some suggestions from the oven to a hair dryer to a paint remove gun... Link to comment Share on other sites More sharing options...
Guest Posted July 11, 2011 Share Posted July 11, 2011 i put them in the oven but you got to be careful as they melt as you can see on mine on the corner of them. think i may of touched them againsted the side of the oven when taking them out. if your going to do it only put them in for a minute and try and prise, if no luck then another minute should do the trick. i had the oven on full chat so prob what melted them. i might get another set of lights and try again.good luck with them mate. Link to comment Share on other sites More sharing options...
Errordeck Posted July 11, 2011 Share Posted July 11, 2011 thanx for the tip!At how many whatts you put it in? And what did you use to seal them again? Reheat oem kit? Link to comment Share on other sites More sharing options...
Guest Posted July 11, 2011 Share Posted July 11, 2011 Hi, can you post some pictures how you've mounted the fog lights and how you've wired them (or at least some ideas).And one advice - HIDs without focusing lenses and on stock headligths (with the fresnel condeser) are really blinding for oncoming vehicles.ive just cut the plastic to fit them, its a bit of a gash job but you canot tell from a distance. as for the wiring just google fog light wiring, im sure you will find something. i just wired them straight to the battery via a switch and a fuse. as for the hid's, i dobut they blind anyone as they are useless. high beam is no higher than dipped and ive not had anybody flash at me yet. i think im gona remove them anyway as they are so dreadfull down not lit up roads at night. Link to comment Share on other sites More sharing options...
Guest Posted July 11, 2011 Share Posted July 11, 2011 thanx for the tip!At how many whatts you put it in? And what did you use to seal them again? Reheat oem kit?dont know on wattage, just cranked it up nearly full, for the resealing, the glue was still really soft so i just pushed them back on and it did the job. ive had no moisture in them at all and i did them a while ago. Link to comment Share on other sites More sharing options...
DanT Posted July 11, 2011 Share Posted July 11, 2011 looks really nice,they deffo look best in white Link to comment Share on other sites More sharing options...
