need an answer on a manifold quick ??
belfastlad123
  • Replies 28
As long as the engine 'series' is the same mate, you should be fine.
I would change gasket, but bolts are fine to re-use, just put a little bit of copper slip on the threads when you bolt them in!
Just make sure you use a single hex socket mate, better for the rusting nuts as it won't round them.
All the manifold's I've changed, I've never snapped a bolt, just make sure the not over torqued!
