pjw Posted May 24, 2011 Share Posted May 24, 2011 my car pulls to the right when i put the foot down, and the left when i take it off. Ive had a look at the wheels and nothings obviously knackered, the only thing i noticed is that the camside engine mount isnt that tight, and if i rock the engine the metal sleeve will move around on the rubber. could this realistically cause the car to pull to the right? Link to comment Share on other sites More sharing options...
syzsounds Posted May 25, 2011 Share Posted May 25, 2011 My aerodeck does the same thing PaulOh and welcome to Rovertech... Link to comment Share on other sites More sharing options...
johngreen537 Posted May 25, 2011 Share Posted May 25, 2011 wheels / Tyres mate! Mine did exactly the same thing!Changed the wheels, probelm went away! Link to comment Share on other sites More sharing options...
pjw Posted May 25, 2011 Author Share Posted May 25, 2011 nah somethings loose, others have suggested the tie bars from the bottom of the strut to the front chassis - is this a common fault? Link to comment Share on other sites More sharing options...
johngreen537 Posted May 25, 2011 Share Posted May 25, 2011 Doubt it mate. I doubted it too when someone said it was my tyres too, if you've got a second set of wheels you can borrow to try it, you'll be surprised! Link to comment Share on other sites More sharing options...
pjw Posted May 25, 2011 Author Share Posted May 25, 2011 might swap them left for right and see if the problem moves - i know something up suspension wise as i can hear it clunking though, which sort of ties in Link to comment Share on other sites More sharing options...
noodels Posted May 25, 2011 Share Posted May 25, 2011 take it for GEO check hunter laser ect get print out job done.well you will know the area anyway then DIY Link to comment Share on other sites More sharing options...
johngreen537 Posted May 25, 2011 Share Posted May 25, 2011 might swap them left for right and see if the problem moves - i know something up suspension wise as i can hear it clunking though, which sort of ties inThe worst it happened to me was on momo 17's, i swapped fronts to back and it calmed down a lot, but only went away when i took them off! Beleive me mate, I know how rediculous it sounds, I thought the same, yeah right, how can wheels / tyres do that........viewtopic.php?f=56&t=5748&p=55602&hilit=pulling+acceleration#p55602viewtopic.php?f=56&t=6004&p=58861&hilit=pulling+acceleration#p58861viewtopic.php?f=56&t=3968&p=34778&hilit=pulling+acceleration#p34778Thats just the top 3 search results Link to comment Share on other sites More sharing options...
noodels Posted May 25, 2011 Share Posted May 25, 2011 yep exagerated by offset tyres wheels ect Link to comment Share on other sites More sharing options...
civicturbo79 Posted May 26, 2011 Share Posted May 26, 2011 You need to check all the front suspension bushes for play and the front ball joints with a bar for play , sounds like you have something badly warn part on the front suspension .Rich. Link to comment Share on other sites More sharing options...
