johngreen537 Posted June 28, 2011 Share Posted June 28, 2011 The issue is not with the pully, or aftermarket ones mate, its due to cheap ones not having harmonic dampening.I'm sure there are safe ones out there, just steer clear of solid alloy ones with no damper. Link to comment Share on other sites More sharing options...
noodels Posted June 28, 2011 Share Posted June 28, 2011 that is in deed a great info but the oem pulley does not have any rubber in the middle ...and doesn't the ek9 oem pulley in aluminiun ? way lighter than the others!other question...same thing on the flywheel right? how about aplying the oem b18c6 in a c4? good or bad?it would work well with your cams Ima oem integra/ek9 flywheel gearbox> or y211 second 0-100 kph better with the box standard mb yours maybe 6.? sec Link to comment Share on other sites More sharing options...
