james Posted October 28, 2011 Share Posted October 28, 2011 If And When You Are Wanting To Jack Up Your Beautiful Civic (This Covers The M Model Only) Here Is A Handy Guide To Look At THIS CAR WEIGHS 1.2 TONNES AND GOING UNDER WITHOUT KNOWING WHAT YOU ARE DOING IS A BIG NODONT ATTEMPT TO USE A JACK AS A SUPPORT IT COULD SLIDE OFF OR FAIL AND DROP THE CAR ON YOU The Tools/Equipment You Need To Put Your Car Safely On Axelstands Are:Flat Surface (Jacking Up On Uneven/Unstable Surfaces Is Not Safe)4 Or 2 Axel Stands (I Use Halfords 3 Ton Ratchet Axle Stands)A Jack (I Dont Recommend Using The Boot Jack As It Is Not Stable, I Use A 4 Tonne Trolley Jack)Wheel Brace (17mm If Using A Scoket)Something To Kneel On (Optinal)First Get The Wheel Brace And Loosen The Wheel Nuts On The Wheels You Need To Remove, One Full Turn Of A Wheel Brace Is Enough To LoosenSTEP 1 FRONT Next You Need To Jack Up Where You Will Be Working On If You Need Access To The Whole Underneat Of The Car You Will Need 4 Axel Stands. Start Buy Getting the Jack And Jack Up The Front Of The Car First Using The " JACK LIFT PLATFORM " Center Your Jack Cup Under It And Jack Tell It Just Touches And Check The Position Is Correct, Continue Jacking Tell The Jack Stops.Get Your Axel Stands And Place Them Under The "FRONT SUPPORT LIFT BLOCK", Extend The Stands So They Touch The Support Lift Block Then Release The Trolley Jack Pressure SLOWLY While Watching The Stands Are Making Good Contact, Check The Axelstand Are Positioned Under The Lift Blocks And Are Centered For Both Left And Right , Remove The Trolley Jack And Move It To The Rear Of The Car.STEP 2 REAR Now To Put The Rear Of The Car On Stands, Place The Jack Under The Rear " JACK LIFT PLATFORM " (TIE DOWN BRACKET) Jack Tell The Cup Touches And Make Sure It Is Correctly Positioned, Jack Tell The Jack Stops.Get Your Axel Stands And Place Them Under The "REAR SUPPORT LIFT BLOCK", Extend The Stands So They Touch The Support Lift Block Then Release The Trolley Jack Pressure SLOWLY While Watching The Stands Are Making Good Contact, Check The Axelstand Are Positioned Under The Lift Blocks And Are Centered For Both Left And Right , Remove The Trolley JackYour Car Is Now On Axelstands And Assuming You Have Followed This Guide It Will Be Safe To Work UnderIf You Want To Put Only One Side On Stands You Need Only 2 Axel Stands And Follow Ither Step 1 Front Or 2 RearHere are the "jack lift platforms" front and rearAnd the "lift support points" for the front and rearA view from on top of what you should be looking for if you want to jack up the front Link to comment Share on other sites More sharing options...
NIKH25 Posted October 28, 2011 Share Posted October 28, 2011 Good guide James, nice one Link to comment Share on other sites More sharing options...
james Posted October 28, 2011 Author Share Posted October 28, 2011 make it a sticky ? Link to comment Share on other sites More sharing options...
NIKH25 Posted October 28, 2011 Share Posted October 28, 2011 reckon so Link to comment Share on other sites More sharing options...
Didjeridave Posted October 30, 2011 Share Posted October 30, 2011 Deff make this a sticky. Sorry for the horror story, but my old man's mate was crushed by a collapsed jack (believe me, I've had that story just about every time he's known me do anything more than a wheel change without a stand!!). Our hondas are pretty well equipped when it comes to jack points but when placing stands it's easy to wrongly think something's load-bearing. Good job james! Link to comment Share on other sites More sharing options...
noodels Posted October 31, 2011 Share Posted October 31, 2011 an OLD mate of mine asked me to remove a towbar of a 7series bmw once,it was sitting low at back i thought was because of the pinto engine in the boot.lifted it up with a scissor jack so i could get under there better.undone it all I THOUGHT!!!!!!!!!!!!!! came to let the lil jack down and it exploaded.there was no struts on the car when down to the wheel well i would have been killed outright he didnt come out of the house for another 20 mins!!!!!!!!!!!I wouldnt have been writing this .i could have f*****g killed the t****r i dont see him anymore i could never forgive him he is a cont.. I am better of whithout him Link to comment Share on other sites More sharing options...
james Posted November 1, 2011 Author Share Posted November 1, 2011 holy cowtheres no doubting it if a civic falls on you your toast, there too low Link to comment Share on other sites More sharing options...
