HELP: Engine, What Else Do I Need?
harVTEC
Alright everyone,
I'm taking my engine out next month to do the clutch, I thought I may as well take it out and give the engine bay a clean etc.
I plan on doing a complete service while it's out including headgasket and cam belt.
Basically I have a list of everything I needed and have got, could people tell me what else I may need please?
OIL
OIL FILTER
CLUTCH KIT
FUEL FILTER
POLLEN FILTER
AIR FILTER
GEARBOX OIL
TIMING BELT
FULL GASKET KIT
COOLANT
Before I start I want to have everyhting, I am using OEM parts only.
Thanks in advance for any help :)
harVTEC
drive shaft oil seals,water pump, cambelt tensioner, gear selector seal :idea:
oh undo the crankshaft pully bolt b4 removal of engine :idea:
Hi,
Thank you :) I have just got a water pump, however I'm not sure what part is the drive shaft oil seal. If you get a minute could you tell me what part it is on this diagram http://www.hondaoriginalparts.com/honda_car_parts_selection_pfk.php?block_01=17ST311&block_02=B__2100&block_03=17466
Also where would I get the gear selector seal? Is it a gearbox part?
Thanks for your help.
harVTEC
