Weather Strips......
pcdee
  • Replies 42
Top Posters In This Topic
They can stay how they are then lol, do you have to take off the door cards?
i nearly had to! but got away with it! 3 clips wasn't clipping down properly! but they clipped down in the end thank god :)
A guy in the scrapyard showed me how to get them off without damaging the clips (especially that little white on at the end). Takes 5-10 minutes each strip.
He took the external, vertical, black plastic finisher at the open edge of the front door which is held on by a couple of screws behind the inner rubber door seal and a few clips.
With the finisher out of the way you can now see the little white clip which stops the weather strip from sliding out.
Get a couple of small screw drivers to compress the sides of the white clip and carefully lift weather seal up so clip is clear of its location hole.
Once out of the way you can then slide the weather strip out leaving the blue clips attached to the door which can then be easily taken off.
The rears are similar but the white clip is at the hinge end of the door. Again remove the external black plastic vertical door finisher first.
Job done.
It really works!!. Prior to that I was using a cordless drill with a hole saw on the donor car to cut a small access hole in the door so that I could access the white clips.
Was that in cars in the scrap yard? If so did they not hear you doing that or just didnt mind?
