9200rpm Posted February 4, 2012 Share Posted February 4, 2012 hi all ie wheel offset 4x114 or 4x100 all civics exept 5 stud most are 35 to 40 offset depending on whl manufacturer for example if you were to use say a 50 mm offset the wheel would prob hit shock or inner arch for example if you were to use a 20mm offset it would hit outer wheel arch 50mm offset has less metal on the back of wheel ie sits further in hope this helps you all a bit Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted February 5, 2012 Share Posted February 5, 2012 MB6 offset is 55 and other M's are 45. Quote Link to comment Share on other sites More sharing options...
9200rpm Posted February 5, 2012 Author Share Posted February 5, 2012 yes i know was only using them as examples Quote Link to comment Share on other sites More sharing options...
Stanley Posted February 7, 2012 Share Posted February 7, 2012 To sum up, the higher the offset number, the further the wheel sits in towards the body of the car.The lower the number, the further the wheel sits out from the body of the car. Quote Link to comment Share on other sites More sharing options...
knight Posted February 7, 2012 Share Posted February 7, 2012 Info here already >>>>>>>>>> http://www.civic5.com/wheel-info.php Quote Link to comment Share on other sites More sharing options...
