Exchange at ECU from P9K us P72
civicvti
  • Replies 27
Top Posters In This Topic
Yes, a good mod; the US P72 (Integra GSR) is a slightly more aggressive tune for the B18, plus you can chip it later. Also probably the easiest ecu swap for the B18; P28/30s can also be used but you'll have to chip & install a base-mapped ROM (not a big job though really!).
I mounted P72 003 AS, modifying as the site says, the engine is much better the vtec comes first making it more powerful lower, the only sad note is that when I did get the limiter came into the ECU error, the yellow light came on engine failure, although the engine continued to run perfectly.
What do you think can be?
