civicvti Posted April 7, 2012 Share Posted April 7, 2012 It possible change Ecu P9K with P72 without modify map? Quote Link to comment Share on other sites More sharing options...
civicvti Posted April 7, 2012 Author Share Posted April 7, 2012 It possible change Ecu P9K with P72 without modify map? Quote Link to comment Share on other sites More sharing options...
Didjeridave Posted April 7, 2012 Share Posted April 7, 2012 Yes, a good mod; the US P72 (Integra GSR) is a slightly more aggressive tune for the B18, plus you can chip it later. Also probably the easiest ecu swap for the B18; P28/30s can also be used but you'll have to chip & install a base-mapped ROM (not a big job though really!). Quote Link to comment Share on other sites More sharing options...
civicvti Posted April 7, 2012 Author Share Posted April 7, 2012 Then unmount P9K and I mount P72 003 AS and try to see how it goes Quote Link to comment Share on other sites More sharing options...
noodels Posted April 7, 2012 Share Posted April 7, 2012 let us know if you get better resultsps jdm info herehttp://cars.homenetcs.co.uk/honda-civic ... ns-ecu.htm Quote Link to comment Share on other sites More sharing options...
civicvti Posted April 7, 2012 Author Share Posted April 7, 2012 I mounted P72 003 AS, modifying as the site says, the engine is much better the vtec comes first making it more powerful lower, the only sad note is that when I did get the limiter came into the ECU error, the yellow light came on engine failure, although the engine continued to run perfectly.What do you think can be? Quote Link to comment Share on other sites More sharing options...
