Exchange at ECU from P9K us P72
civicvti
  • Replies 27
Top Posters In This Topic
Search 'read ecu codes' - but basically you connect a piece of wire between the two-pin connector near where the ecu is located (there's a two and a five pin conn, both blue). Turn the ignition key to on (don't start the engine) & the engine fault light will blink to give you the code.
