Krzys Posted May 1, 2012 Share Posted May 1, 2012 After 10 mins the fuses would of went back inLeft mine out for 6 hours Took it out when I got to work, put it back in at lunch time Least you could be sure it was done then Quote Link to comment Share on other sites More sharing options...
fyfie5 Posted May 1, 2012 Share Posted May 1, 2012 this seems too easy to be true? is it really as easy as said above? if so i might have a go at it Quote Link to comment Share on other sites More sharing options...
Ianan Posted May 1, 2012 Author Share Posted May 1, 2012 Well, tried as described above leaving it 20 mins before returning the fuses ran it for another 20 mins, shut her down and restarted straight away. Result : NO difference ! Quote Link to comment Share on other sites More sharing options...
noodels Posted May 1, 2012 Share Posted May 1, 2012 checked all vacuum pipes :idea:also see if vacuum pipe holds vacuum Quote Link to comment Share on other sites More sharing options...
