Shaddow Posted May 4, 2012 Author Share Posted May 4, 2012 Thanks Shebabby, will try this tomorrow.And when I had it at garage, car was up on ramp, so wheels not lifted. But still could not see anything that would cause the problem. Ill let you know the results of the rocking of the steering. But could possibly be, as it generally happens when turning the wheel about 45Deg coming off a roundabout. Hmm,... Quote Link to comment Share on other sites More sharing options...
MBK89 Posted May 5, 2012 Share Posted May 5, 2012 Did you check the ARB and drop links on the deck? As with the wheels jacked up the weight difference usually masks out the play Quote Link to comment Share on other sites More sharing options...
Shaddow Posted October 4, 2012 Author Share Posted October 4, 2012 Found the problem, as MBK89 says, it was the drop links. Strange it was not picked up by garage when we had the car up on ramps. Went for a drive the other day and had a huge "Clunk" as I made a turn in the road with quite a bit of camber. Putting the car up on ramps that night showed my Driver side drop link completely broken into 2 parts.New fleabay ones ordered. Could not bring myself to spending £50 each from Honda. Quote Link to comment Share on other sites More sharing options...
WilkesyMB6 Posted October 4, 2012 Share Posted October 4, 2012 I think im having the same problem, and when mine was on the ramp we couldn't see it either. I have replaced them before so when it first did it with mine i thought it was drop links. I haven't checked again but i will do soon and replace them. Quote Link to comment Share on other sites More sharing options...
