METAL brake pads
crazycustomz
i guess you mean carbon metalic ones if so what make does your mate run ?
i have mintex F stuff not cheap ( i use hamp ones the road ) £150 for the front only but they rearange your internal organs when hot but i do not run them on road ( when i get back on track too much stuff going on lol )
mate is useing same ones in his race Mr2 cause i told him too try them thinks they are VERY VERY GOOD
this is where i got my mintex from they where DC2 ones
http://wbs.msauk.org/trade/ShowSite.asp ... erId=QUEST
padgid pads also good but not the normal ones theses sell them plus DS3000 ( DS2500 are just a fast road pad ) Questmead sell too race and rally teams so they can get most good makes
ring direct the web link is from the MSA and they will advise you what too get depending on every thing
there will be loads of brake dust and its harsh so white wheels are a bad choice if you have them just warning i found out the hard way on my 309 :roll:
how quick do these ware out
Carbon Metallic delivers more stopping power than any other brake pad
Multi-layer Technology reduces noise by absorbing specific ranges of sound frequencies
Less fade, less wear and less noise when tested against leading competitors
Unique friction material outperforms ceramic and semi-metallic pads in noise and vibration tests
Meets all environmental standards - including newly passed copper limitations
Consistent pedal feel stop after stop - No mushy pedal, No fade
Sounds good! :)
Most brake pads now have a heavy steel fibre content.
The 'more sporty' the pad, the less metal it generally contains!
Carbon Ceramic pads are so good as they contain only a trace of metal / steel content, the ceramic dissipates heat transfer and the carbon is the organic material that actually does the stopping!
RS4-2-1 is the brake composition standards ISO if anyone fancies a dull read :)
